Apparently Media Server not connected
Hi guys,
i can't figure out why Medialink on my LG TV has stopped working, so i wanted to try PlexConnect. I can't get it to work, so i'd ike to ask for your help!
  • Your ATV model (2 or 3) and firmware version (found under the ATV settings > general > about > Apple TV software): ATV3 with firmware 6.0.2
  • The DNS server set on the ATV (found under the ATV settings > general > network > DNS): 192.168.0.13
  • The local IP address of the device that PlexConnect is installed on: 192.168.0.13
  • The device and operating system (including version number) that PlexConnect is installed on: Macbook Pro 5.4 with OS X 10.9.1
  • The device and operating system (including version number) that the Plex media server (PMS) is installed on: Macbook Pro 5.4 with OS X 10.9.1
  • The Plex media server (PMS) version number you are running: 0.9.8.10.215-020456b
  • The local IP address of the device that the Plex media server (PMS) is installed on: 192.168.0.13
  • The PlexConnect version number: Standard Setup. Download date January 9th 2014
  • The contents of your 'Settings.cfg' file (this is created at first clean shutdown of PlexConnect, using CTR+c):
    [PlexConnect]
    port_pms = 32400
    port_webserver = 80
    ip_plexconnect = 0.0.0.0
    certfile = ./assets/certificates/trailers.pem
    ip_dnsmaster = 8.8.8.8
    loglevel = Normal
    enable_dnsserver = True
    logpath = .
    ip_pms = 192.168.178.10
    enable_plexgdm = True
    hosttointercept = trailers.apple.com
    port_ssl = 443
    enable_webserver_ssl = True
    prevent_atv_update = True
    port_dnsserver = 53
    enable_plexconnect_autodetect = True
  • detailed description of the issue (the clearer you can make this the better): On Apple Tv after opening the Trailers App there is no content available in all categories. Also in Settings it states „Plex Media Server: 0“.
  • Ensure you post your 'PlexConnect.log' file to pastebin and post the link ('PlexConnect.log' is located in your PlexConnect folder). If possible, follow these steps to create a "more detailed fresh" one: See Attachement
Thank you in advance!
Regards,
Paulo
Nevermind, looking at the settings.cfg i found the mistake myself. Changed the IP and it worked.
