AUthorized device Renaming
Server Version#:1.32.8
Is there an option to rename the Authorized devices to the plex server to tag properly and manage the end devices using services.
In Android mobile app Settings > Experience, change the Friendly Name. Then force stop and relaunch the app and stream something for a few seconds.
Authorized Devices will pick up the new name.
Should be similar for Android TV.
You cannot change it from the server.
@FordGuy61 , that worked, thanks…
