Autotag not working
For some reason autotag is not producing any results. Previously it worked properly when I tried it with couple of small libraries with only tens of photos. Now that I set my whole photo library to use autotags, it doesn’t seem to work. Logs are filled with warning messages “WARN - AutoTagging: skipping item 44575 as we have failed to process it multiple times (4)”
I have set tagging on and library language to english in my photo library options. Server version is 1.11.0.4666.
Please see the attached log.
Any ideas?
Thanks for the report.
We’ve found a bug where if the autotagging service is throttled it can cause items to become stuck (not able to tag) if a refresh is run multiple times on the library.
A fix has been submitted which should hopefully make it into one of the next two releases.
Currently the only work around in the current release for this would be to remove the library and re-add it however it would end up in the same state if you’re still throttled.
Thanks for the answer. What do you mean by throttling? Just asking because I don’t want to make the same mistake twice :slight_smile:
Cheers,
-Kaj
Cheers,
-Kaj
We use a third-party provider for the autotagging service so we allow a certain amount of requests per user before the service gets throttled and the service will be temporarily unavailable until the throttle state is lifted.
The server will continue trying to tag the photos during its maintenance window as a scheduled task so you don’t have to worry about doing anything manually as the images will get processed automatically over time.
You can read this article: https://support.plex.tv/articles/234976627-auto-tagging-of-photos/ for more details, we’ll continue tweaking the throttle rules to ensure that all users get a fair share of the resource with the least amount of impact.
This change was announced in this sticky thread: https://forums.plex.tv/discussion/297791/notice-auto-tagging-will-require-pms-1-9-3-or-newer-starting-december-1st-2017#latest
Would it help if the photos are in several smaller libraries instead of one big? That way I wouldn’t send such a large number of requests at once.
-Kaj
-Kaj
No, the size of the library doesn’t affect this as it would still be same amount of photos.
OK, guess I will wait for the problem to be fixed in the next two releases.
Thanks,
-Kaj
I have setup my server on a synology NAS using the latest version (1.12.1.4885). Autotagging is important for me as I am using the server for my work to manage stock photo collections. I have not had a single photo auto-tagged in the process. The logs show the message “AutoTagging: the service is currently throttled, skipping item …” on all items. The workaround suggested is not an option. As mentioned in the same post above suggesting that deleting and recreating libraries is the workaround, the account will continue to be throttled.
What is your updated timeline for getting this issue resolved? The only reason I purchased the plexpass subscription was to have the auto-tagging feature.
I’m still seeing “AutoTagging: the service is currently throttled” on all items with the 1.12.1 4885 release. When is this getting fixed?
Hey!
Is there any news on this topic? I’m still having this issue. I just updated to the latest Version of Plex (Plexmediaserver_1.15.2.793-782228f99_amd64) but the logs still say the service is throttled.
Hope to hear good news about this, soon. :slight_smile:
Hello
I am having the same problem. My library’s haven’t been autotagged at all since I uploaded them months ago. This is an important feature for me and would appreciate if you could communicate if this service is going away or if you are working on a fix.
platform: Linux
version: 1.15.4.919
me too
And me. I can manually tag and everything is properly enabled, but no joy. I have 30k+ photos to organise, so tagging is fairly critical.
I’m having the same issue. No autotagging at all and I have thousands of photos that could use tags. Any updates?
Same here. News would be appreciated.
Problem for me too
Same here. Tried deleting/creating my library, enabling/disabling autotagging… no success.
Can’t find a solution to this problem.
I’m following releases (currently 1.16.3.1402) in the hope that a fix will be available, without luck for the moment.
If you have ensured that the option is enabled in the library settings, then the most likely reason why it would not be working is that the service is throttled for your account due to the max limit being reached.
If throttling is the reason you will see lines like this in your log file:
See our support article on Autotagging which has all these details: https://support.plex.tv/articles/234976627-auto-tagging-of-photos/
Yes, the service is throttled. I see that in the logs.
But it’s throttled for months, and no tagging happens.
After several months of waiting, as soon as I enable autotagging, the service is throttled, whereas it should autotag 10K pictures per rolling month.
I can confirm that - I have aroung 7000 pictures in my library and none of them were ever tagged until today! And yes I saw the support article on Autotagging.
I have a plex pass since the 25th of may, I recreated the picture libary and played around with the settings in June for testing, but I didn’t touched the picture library in July. And now in August the service is still throttled. I can provide logfiles of the same ~7000 items and the service is throttled from June to August.
It would be really nice if you could look into that problem.
