Bad Quality on Remote Streams
Hey Guys,
my PMS is running under windows. iIt works fine for me except one thing…
When I am steaming my content remotely that I have always to set the quality to original.
I got 40 Mbit/s Upload and soon 200 Mbit/s Upload, so there should be no Problem to steam HD/4K Content remotely.
I set the Upload Speed to 40 Mbit/s and set the Quality to no Limit.
Is there any Options to set the Quality auto to original Quality?
Thank you in advance.
Cheers,
Julian
Server Version#:uptodate
Player Version#:uptodate
you change it in the player app itself. if you are using the web app player you set that here to make it the default for that instance of the player
Thank you for your support.
I set this to maxiumum. It still plays on 0,3 Mbps when i click start stream on my iPhone.
When i click on stream in original quality it plays it on original quality with no problems.
Hope someone can help me to fix this. Thank you.
did you also change it on your phone? Each player will have it’s own quality settings. a phone will also have an additional setting of quality over cellular.,
Thank you BugWheel - Thats was the setting i didnt set - Now i can stream at max quality on each remote player.
Thank you for the Support.
