Baseball season 2 can't Fix Match
Server Version#: 4.141.0
I am trying to fix Match Match Baseball Season 2 by Ken Burns, and unfortunately, it does not work. Season 1 is fine. Does this mean I will have to do this manually? I have done the Plex Dance to clear the cache, but this has not worked. Just want to know if anyone has any other solutions to get this to work.
Is it on tvdb or tmdb? (if so can you link it?)
This show is listed differently on TMDb and TheTVDb.
If you organize it according to TheTVDb, make sure to tell Plex!
TheTVDb
  • 8 Specials
  • Season 1: 9 episodes
  • Season 2: 2 episodes
TMDb
  • 13 specials
Depending on how your files are organized:
  1. Edit the show in Plex ( :pencil2: )
  2. Select the Advanced tab
  3. Set the Episode Ordering accordingly
Thanks a million @tom80H. This has really helped.
