Best version of Plex Docker for Unraid?
Server Version#: 1.20.5.3583
Player Version#: 4.43.4
Hi all,
I’m trying to determine the most recommended version of Plex to run on Unraid.
I’m currently using the linuxserver image of Plex, but I don’t know if there is any advantage to using the official image.
I just wanted to find out and perhaps discuss if I should switch and if there is any differences that people have noticed?
Also, are there other distributions that I should consider?
Thanks for any advice.
This is an update for anyone who may find this.
I was able to switch over pretty painlessly, by feeding the appdata directory of my Plex install from the linuxserver installation into my official install, and everything matched up well.
Do a backup first.
