[Bug 7.6.0.6822-beta] Artwork Goes Missing after Playback
I rebuilt everything…
The library… the cache… the server settings… the whole folder was deleted…
It happened before a rebuilt… and after a 100% rebuild on “EVERYTHING…”
And only the Shield does this?
I have a FireTV as well… But it is running Plex for Android 7.4.0… Where this bug doesn’t exist.
Once it updates to 7.6 or higher ill report back. ( Although I don’t like updating to broken releases to beta test apps that don’t get fixed )
7.4 also doesn’t suffer the fast forward bug either… On firetv and shield.
Still broken
Is this ever going to be fix or acknowledged?
I still can’t reproduce this issue and there was nothing in your logs before. Do you know how to generate a Logcat. If so, reproduce the issue and provide that might give a clue.
Didn’t I already do that in the above log? or is that Logcat different.
A logcat is different. It actually captures data at the OS level. It’s a debug tool for Android that you typically run from a connected computer. It dumps a lot of data so it should only be used for specific tests.
