Posters missing on Android Devices
Server Version#: 1.29.1.6316
Player Version#:9.9.035519
Has anyone ever found a reliable fix for this? Nothing mentioned in:
https://forums.plex.tv/t/android-client-no-posters/67387
https://forums.plex.tv/t/posters-disappeared-on-android-devices/773979
https://forums.plex.tv/t/posters-missing-on-android-tv-client-only/778849
https://forums.plex.tv/t/posters-missing-only-on-android/455091
https://forums.plex.tv/t/android-tv-plex-app-needs-to-cache-poster-background-art/183111
https://forums.plex.tv/t/movie-posters-missing/492986
And other threads works for me, and most similar threads close without a response.
This only seems to happen with the Android client. Plex via the web works fine.
It’s a bummer that it’s still an issue.
The person in Android client - no images / art work / posters when using "manual connection" - #3 by cecoates explained it in a way that worked for me.
The Android app won’t load artwork if you’re not using 32400, even if you’ve manually configured your settings to use that port. The web view works fine, so this bug seems Android app specific.
Changing my Plex port back to 32400 fixed it instantly. It’s frustrating, because running two servers isn’t THAT unusual of a use-case, so it should be designed in a way where you don’t have to use one specific port or artwork breaks.
Something to try if you’re running into similar issues.
