[BUG] Could not fit playback within bandwidth limit of 96kbps
Server Version#: 1.19.3.2764 (QNAP)
Player Version#: 6.12 (iOS)
When setting the quality of music playback to 96kbps (Remote Streaming) it fails to play back at all. The error in the logs is pretty straightforward “not enough bandwidth” (last line down below). Looks like it’s trying to transcode to 101kbps instead of 96kbps.
This seems to be a bug in recent versions of the iOS app OR maybe is has something to do with the new iPhone SE (2020) since I only discovered this behavior after switching from my 5s.
May 13, 2020 14:18:02.658 [0x7f52586a4700] Debug — MDE: Dissolve Dissipate: Direct Play is disabled
May 13, 2020 14:18:02.658 [0x7f52586a4700] Debug — MDE: Cannot direct stream audio stream due to codec flac when profile only allows opus
May 13, 2020 14:18:02.658 [0x7f52586a4700] Debug — MDE: Dissolve Dissipate: selected media 0 / 101743
May 13, 2020 14:18:02.658 [0x7f52586a4700] Debug — Streaming Resource: Calculated bandwidth of 538kbps exceeds bandwidth limit. Changing decision parameters provided by client to fit bandwidth limit of 96kbps
May 13, 2020 14:18:02.658 [0x7f52586a4700] Debug — Streaming Resource: Determining preferred transcode encoders through transcode only decision.
May 13, 2020 14:18:02.658 [0x7f520515a700] Debug — Streaming Resource: Could not fit playback within bandwidth limit of 96kbps
May 13, 2020 14:18:02.658 [0x7f520515a700] Debug — Streaming Resource: Reached Decision id=103391 codes=(General=2001,Not enough bandwidth for any playback of this item. Required minimum bandwidth is 101kbps and only 96kbps is available.)
If I set Remote Streaming to 128kbps everything works as expected.
Nobody with the same problem? Issue still exists with the new version of iOS (7.0)
Resolved:
(Transcoder) Very low-bitrate music transcodes could fail (#11481)
