Server Version#: 1.32.6.7557-7000
Player Version#: 8.26
I found a bug that can cause Plex to jump two episodes ahead instead of playing the next episode of a show.
Reproduction Steps:
- Make sure auto play is turned off.
- Play an episode of a show (or skip ahead) until it ends and brings you to the screen that shows the option to play the next episode under the “Playing Next” heading.
- Double tap the play button for the next episode.
Expected: The Plex client plays the next episode.
Actual behavior: Plex skips over the next episode and plays the following one.
Note: Rapidly tapping the button will cause it to skip more than one episode.
