Server: 1.31.1.6716
App: 9.16.0.38553
[Updated - I missed the related messages in the log, have cut some of the lines down to hide info about my server]
Sometimes playlists fail to download. The app shows a red ! error message that states ‘An error has occurred. Please try again later’
This coincides with the following in the logs:
02-15 14:23:38.778 i: [UserAction] Click item Jazz (/playlists/285059/items).
02-15 14:23:38.784 i: [Download Item] Downloading item with uri No uri provided
02-15 14:23:38.785 i: [Download Item] Asked to download an item but not given a location.
02-15 14:23:38.788 i: Fetching [method:GET] https://192.168.1.150:32400/playlists/285059/items?X-Plex-Sync-Version=2&X-Plex-…
02-15 14:23:38.932 i: Creating PreplayPlaylistActivity.
02-15 14:23:38.950 i: [Boot] PreplayPlaylistActivity took 1ms to run create behaviours.
02-15 14:23:38.953 i: Resuming PreplayPlaylistActivity.
02-15 14:23:40.497 w: [Sonos] Nearby discovery socket timed out, probably because there aren’t devices nearby
02-15 14:23:40.628 i: Fetching [method:POST] http://127.0.0.1:32500/media/providers?url=server…
02-15 14:23:40.639 i: [HttpServer] /127.0.0.1:53006 - POST /media/providers
02-15 14:23:40.697 w: [PlexPivot] Pivot ‘Timeline’ not supported as view ‘/media/providers/1view://photo/timeline’ is not defined
02-15 14:23:40.698 w: [PlexPivot] Pivot ‘Timeline’ not supported as view ‘/media/providers/1view://photo/timeline’ is not defined
02-15 14:23:40.709 i: Fetching [method:GET] https://192.168.1.150:32400/library/sections?X-Plex-Token=…
02-15 14:23:40.738 i: Fetching [method:GET] http://127.0.0.1:32500/media/subscriptions/template?guid=com.plexapp.agents.none…
02-15 14:23:40.751 i: [HttpServer] /127.0.0.1:53008 - GET /media/subscriptions/template
02-15 14:23:40.763 e: Error fetching http://127.0.0.1:32500/media/subscriptions/template?guid=com.plexapp.agents.none…
Navigating to my ‘Jazz’ playlist in the web UI, the URL contains the following:
/playlist?key=%2Fplaylists%2F285059&context=library%3Acontent.playlists.music~0~4
Sometimes the regular ‘Download’ dialogue appears but the playlist still isn’t downloaded.
Trace related to this behaviour is below:
02-15 16:00:14.969 i: [UserAction] Click item Rock (/playlists/285061/items).
02-15 16:00:14.971 i: [Download Item] Downloading item with uri No uri provided
02-15 16:00:14.971 i: [Download Item] Asked to download an item but not given a location.
02-15 16:00:14.975 i: Fetching [method:GET] https://192.168.1.150:32400/playlists/285061/items?X-Plex-Sync-Version=2&X-Plex-Token=…
02-15 16:00:15.143 i: Creating PreplayPlaylistActivity.
02-15 16:00:15.154 i: [Boot] PreplayPlaylistActivity took 0ms to run create behaviours.
02-15 16:00:15.156 i: Resuming PreplayPlaylistActivity.
02-15 16:00:16.125 i: [UserAction] Select menu item: Up.
02-15 16:00:16.182 i: [device] Setting selected server to HTPC version: 1.31.1.6716-ca0c45ff8 owned: true home: false videoTranscode: true audioTranscode: true deletion: true class: null, presence false
02-15 16:00:16.187 i: Resuming HomeActivityMobile.
02-15 16:00:16.188 e: Presenter not found! Type: unknown, Subtype: unknown
