BUG: "Enhanced Guide" DVR setting: Missing show/movie posters from LiveTV & DVR
Server Version#: 1.23.2.4625
Player Version#: Web Player/Latest Android
Tuner Make/Model: xTeVe latest
Guide/Lineup name: TVGuide
Using XMLTV?: Yes
Channel number/Name: All IPTV channels
Artwork for TV Shows and Movies are not showing up anymore for IPTV channels. This used to work perfectly a few months ago when “Enhanced Guide” setting was enabled. Unfortunately, recent threads reporting this issue seem to get overlooked. Is there a better place to report Plex issues?
I also noticed this today
UPDATE: I was able to find a workaround. I switched to an EPG provider to supply poster artwork for each airing.
However, the actual problem is that Plex developers seemed to have recently broke the “Enhanced Guide” LiveTV DVR setting. This setting is “supposed” to supplement missing poster artwork, but doesn’t anymore. The only workaround is to use an xmlTV provider that already provides this artwork.
Same issue here!
Can we have fix please? As this is Plex Pass paid for functionality :slight_smile:
@sa2000 I see you were tagged in one of the posts linked above. Could you take a look please?
Cheers
To follow it up, I would need an actual current xmltv file to try and zipped server logs after a refresh and the attempt to enhance the metadata from the guide
im having the same issue… no enhanced guide data for Live TV & DVR… just blank pics
Thanks @sa2000
I have DM you with the requested files
Also having this trouble with live TV enhanced guide.
Thanks for the xmltv file and logs. I have looked into this and found out the reason. Unfortunately the legacy back-end plex system is no longer operational and the intention is to switch to using our new metadata backend systems. This work has not yet been done.
I will link this forum thread and any others I find to the internal registered issue for this
Hey @sa2000, do we have any updates on this issue?
It is on the list for the development team. I have added a note
Great to hear, I hope this gets resolved soon
Same issue here :confused:
Same issue here. @MKA.NET can you tell me which EPG provider are you using please?
Same issue here :frowning:
I have full artwork/program information/channel icons using guide2go to produce an XMLTV file.
zap2xml also works good for me.
Just bumped into the poster issue myself hoping for progress. Any news on it?
It’s weird how some obvious bugs like this take YEARS to fix. It can’t be that hard to fix.
I don’t have an update. The Enhanced Guide option functionality is no longer there. I have added a note on the open issue
