BUG: External xml epg = guide collision (Grid View only)
Server: 1.26.2.5797
I know this may be a somewhat esoteric issue, but I have multiple tuners (1 physical and 3 virtual) each with separate xml EPG source. Recently, (maybe a version or two on the beta) I’ve been getting guide collisions with shows showing up in the wrong channel if they have a similar number.
Example: Channel 20.1 has a mix of shows from channel 200.1, 10.1 mixes shows on 100.1. An interesting observation is if I play an incorrect show from the guide, once it plays, the show displays what it should be, however the next (upcoming show) is incorrect.
I’ve combined the xml into one source using Xteve, but the issue still appears. The only way around I’ve been able to do is to remap the channels on my virtual tuner to start at a higher sub-channel, for example make the start number for a sub at 100.11.
guide-channel-collision
More strangeness. Channel 5.1 (FOX) programs colliding with 50.1 (CW).
This is from a single XML EPG file and only in the grid.
Grid view of FOX shows The Flash on channel 5.1
Screen Shot 2022-05-25 at 9.11.20 PM
Episode view shows correct - Flash on CW channel 50.1
Looks like something it may be something with a zero in the channel for the grid view
