Bug in Channel Matching
One big part of the problem is the way the dropdown for EPG channel selection is structured. This does not only affect one EPG with multiple entries with the same channel number but also multiple EPG using the same channel numbers. Here is the first EPG
And here the second EPG
In this case, the tag option value is not unique. After selecting ZDF HD, the menu defaults to ShopHQ and there is no way in changing this to ZDF.
The same would apply with identical channel numbers in the same EPG.
I hope the next version will fix this.
I switched to the Beta channel and installed Plex 1.25.5.5492 with Web 4.69.1. as well as 4.74.1 via plex.tv/desktop.
Unfortunately not fixed for multiple EPG with the same channel number:
This is what I select:
And this is what Plex does:
The html code is still showing the same behavior then shown in my post a few minutes ago.
Lets wait for the Plex Web to come out and then see if there remains an issue with multiple lineups
I did say in my post that I expect the fix to come out in Plex Web 4.75
see Bug in Channel Matching - #21 by sa2000
