Bug: Lost recordings when overlap
Server Version#: 1.22.0.4163
Tuner Make/Model: Hdhomerun Prime
While testing out if I can overlap recordings on the same channel I noticed that I lost some of the recordings after the recording schedule was over. At one point it was recording Wild Kratts and then it recorded the show after it and I checked back, I didn’t have any copy of Wild Kratts on the server. It’s not in the DVR schedule anymore even though it was in there while it was recording.
This seems to be related to this issue but that post is closed now. Bug hunted down: Overlapping DVR recordings of same channel
Side note - Trying that topic’s suggestion of removing partial recordings and what I got was nothing in the second slot recorded (yeah, ok, I told it I didn’t want part of a show), but the error listed says “not enough disk space” when it should probably say “no free tuner”
Plex Media Server Logs_2021-03-19_09-20-31.zip (4.3 MB)
Using a ramdisk for transcoding should come with a warning that it will probably break the DVR operation.
Switch to a real file system.
Why would it need to transcode? I have “convert video while recording” set to off
Because that is where Plex temporarily saves the live buffer segments while you are watching tv and/or assembling the DVR file.
