[Bug] Movie Collection tab same as Library tab on web
I’ve experienced this issue since the recent sever update to 1.28.2.6106.
It only happens to my movie library, not TV libraries.
Both app.plex.tv and local IP returned the same results.
I’ve also tried clearing browser caches with no luck.
But switching to other users doesn’t have this issue (only happen to the main admin user).
CleanShot 2022-08-19 at 09.28.04
The URL does change to “pivot=library” or “pivot=collections”.
What is the value of the ‘Minimum automatic collection size’ option?
If it’s ‘1,’ it may be the cause.
It’s “Disabled” (and has been since I created this library).
(How to display) Collections is set to “Disabled” as well.
Hmm, I don’t know of anything else that would do that. Sorry.
I think someone had this issue earlier this year. Seems to be an issue in the configuration of the web client. Was fixed by resetting the web client back to default. Note, that means you need to reconfigure the web client as if you just logged from the web for the first time. The server itself still has all the metadata and videos, and your account remembers what you watched. But the customizations to the client - such as pinned libraries and what order they are in - will be lost.
Thank you! That does solve the problem, although I’d really want to know what’s the underlying cause of it.
