BUG: Pinned Download section library disappears on reboot and is missing from Home section
Player Version#: 10.8.0.5554 (86193d4)
Specific to Downloads section only when trying to pin it to work with the “Home” section, I mainly use this Lenovo P11 Plus with Plex Downloads when the tablet is offline and the download part works fine but for some reason even though no other libraries are selected “Home” keeps asking me to pin more sources and when I go into “Downloads” and pick “Libraries” and pin my Downloads - TV Shows - SERVERNAME, it appears in the pinned section but Home still says no sources pinned and when I reboot the tablet the pinned source is gone but if I go under Downloads and Library and click the 3 dots, it says “Unpin from taskbar” if I unpin and repin the Library reappears on the bar but Home still says to pin sources and after a reboot the Downloads-TV Shows-SERVER name is gone again and it still says “Unpin from sidebar” under Libraries
The goal is pretty much just to have the plex app open and the same in progress shows and recommended that is shows when you manually browse to Downloads - Libraries - Downloads - TV -Shows - Server Name appear
Maybe it doesn’t consider it a pinned Library? Anyways it disappears after every tablet reboot even when the tablet is connected to the internet so it’s easily reproducible on the latest version of the plex client on the android on the lenovo p11 plus which is Android 12
I have a similar issue that I have posted about with downloads and one of the symptoms is that the pinned downloads section goes away. When this happens and you click on downloads does it error out or have a very slow load time?
Downloads stays pinned but the pinned downloads library disappears and it never populates home, it’s still fast to connect to downloads but you still have to browse down to downloads then to libraries then click the download library then the “home screen” style recommended kicks in
It’s the only source pinned in the plex client so ideally that should be populating the home screen but yeah the downloads tv shows library unpinning on every reboot and not populating the default home screen seems like a bug
Interesting, that is one of the symptoms I have though my issue is larger with downloads than just that.
