BUG : Resume media
Server Version#: Last on date (2021-04-12)
Player Version#: Last on date (2021-04-12)
Since the last version, it takes a long time (x minutes) to resume a media.
Sometimes he starts the media over from the beginning, even though I wanted only resume.
I have the same issue with resume not working,
we are looking into it.
I have the same problem/issue.
Fire Plex app v8.15.0
Media server v1.22.2.4282
Same for me
Nvidia Shield Client: 8.15.2.24006
Windows Server: 1.22.2.4282
I think this started happening after updating the server to newest version. When looking at authorized devices it states that the Shield was last seen a couple of days ago even though I’m using it daily
It only affects the Nvidia Shield (android tv only?)
Windows Webclient works fine.
question. are y’all clicking on the resume button on the preplay/summary screen or just selecting the episode thumb or hitting play button on remote?
@BigWheel I might be able to reproduce it Unable to resume after update Version 1.22.2.4282 - #3 by msmall_paintersquest.com
for me its happens any way you try…I can reproduce it anytime.
Start a video, pause it, let set and go to sleep or kick you back to firestick main screen from time out. and then load Plex and and try to play it. it will restart from the beginning and sometimes if you try to fast forward it by clicking the >> button it will crash/lockup. to get around the >> click and drag the dot that shows the current part of the show/movie
Apparently this is a workaround. Maybe it’s a clue for fixing it.
Same here:
Version 4.56.4
Thank you
