Bug: Skip intro button causes audio lag
Server Version#: 4.54.5
Player Version#: 8.16.0.24423 (Android)
I’ve noticed that each time when I use the SKIP INTRO button, it performs the required task but little by little the audio and video start to be out of sync. When I pause the video, exit and then resume, audio and video are back in sync.
Could this be a bug? It has happened multiple times both with X264 and x265 files.
I have experienced the same thing for many TV shows.
It only happens to me on my shield pro 2019.
I also use the LG WebOS plex client and using skip intro on that client never results in out of sync audio.
Server version: 1.23.1.4602 (synology)
Shield Pro client version: 8.18.2.25850 (0905fbb3)
Shield Pro version: 8.2.3 (32.6.518.0)
LG client version: 5.17.0 (platform version 4.9.0)
This is a known issue with seeking (can happen with any seek) that we’re tracking internally.
@DaveBinM - Any updates or progress on fixing this bug? Is there another place to track when this will be fixed for the nvidia shield client?
I’ll add a +1 as this has never been a problem for me, until recently. I use a Shield if it matters.
Mine is not a subtle shift to being out of sync, its immediate after the “Skip Intro” and I have to exit and resume the media. For me this does not happen doing a normal forward or reverse skip or seek, its only using the Skip Intro feature, and it can only be fixed by exiting and resuming the media.
Same issue
We’ve done a fair bit of investigation on this, and tried quite a few different things, but haven’t been able to track down the exact cause of it yet, I’m afraid.
Same issue, same hardware setup…(Android TV running on NVidia Shield). Just keeping the thread open (and subscribing for updates).
Omzig10
bump to keep the thread alive. Still happening on plex client version 8.28.0
Any new update from this investigation?
i have the same issue on several devices. Is there any update from the devs?
This is still happening on the latest (beta) PMS, and beta Android TV client on nVidia Shield.
Also posted under the following thread:
Video skipping and sync issues on 8.31.0 w/Shield Pro - Plex Players / Streaming Devices - Plex Forum
