Bug - Subtitles cause infinite buffering Nvidia Shield Pro
Server Version#: 1.24.1.4931
Player Version#:8.22.0.27533 (bdaff3f3)
As the title says, turning on Subtitles on my Nvidia Shield Pro (fully up to date) causes an infinite buffering issue with most .srt subtitle files. Video will not play when those subtitles are enabled. Turning off subtitles removes the problem and the file plays fine.
Tried a different Nvidia Shield Pro using the same Windows server and Player Version# 8.21.2.27212 (f3c29f79) and everything works. The same media with the same subtitles from the same server all play with no trouble at all.
Something changed in between those Player versions that is messing with the operation of the Player’s subtitles on the Nvidia Shield Pro.
Someone will probably want to look at that.
Thank you.
