Server Version#: 1.23.6.4881 on macOS
When I attempt to filter TV Show libraries using the “Trash” advanced filter, I see no results. I was using this filter to do some manual library clean up over the last week, and this issue emerged in a recent update, likely 1.23.6.4881.
This is incorrect, since with no filters active, there are multiple library items with the trash icon overlaid. Similarly, when manually doing “Get Info” individual episodes, there are plenty of episodes with underlying files unavailable. These should all show up when the “Trash” filter is activated.
This issue does not emerge in Movie libraries, and it seems limited to TV Show libraries.
Appreciate the help to either investigate whether this is a bug or help me understand how I may be doing something incorrectly. Although, this “Trash” filter was working prior to the update. Thanks.
