I added the movie Cam (2018). I am using some automation, so cannot alter the folder and file name.
Unfortunately., the movie is ignored by Plex. I assume it may be because of the name cam. It is not wrongly picked up, but completely ignored. Full name below. Any thoughts?
Thanks for your message. Yes, thatās not the issue. All other movies work, I reset the permission for this drive. I also removed and re-added the movie. The movie plays well with VLC, too.
My suspicion is that ācamā is seen by Plex similar to āblurayā or ādvdā? But no clue, Any other idea appreciated.
Unfortunately, this did not work. What worked is to rename the movie to a different movie (Cam camera (2018) [WEBDL-1080p]). Now, it is added and I can change the movie to the right one manually.
Is there any chance that Plex can fix this issue? I prefer to have the movie named in the right way Cam (2018). Assume this should be easy to reproduce for the developers. Any chance to help with a bug fix?
Iād like to keep the standard naming if possible.
I believe yours work only because it was picked up as something else? Genre should be thriller and mystery (and is identified as such after I added it under a āfake nameā and the changed the title.
Did you try adding it as ā\Cam (2018) [WEBDL-1080p]\Cam (2018) [WEBDL-1080p].mkvā and is it working for you? If not, it seems to be a reproducable issue that developers may be able to fix for an upcoming release?
I figured out the genre thing⦠I was re-using a test file that had embedded metadata I used as a test for something else. I removed the metadata and plexdance and the genre is now correct. But nonetheless, the movie was, and still is, matching to the correct movie.
You are saying that "\Cam (2018) [WEBDL-1080p]\Cam (2018) [WEBDL-1080p].mkvā works even if added in the exact identical way? If so, it does not seem to be a general Plex issue, but an issue specific to my Plex containter?
Yep. My path \UpcomingTrailers\Cam (2018) [WEBDL-1080p]\Cam (2018) [WEBDL-1080p].mp4
No issues. Granted I have MP4 and you have MKV but I guarantee that wonāt make a difference.
The one thing I can see being an issue is the Plex Dance. Donāt skip any steps. Every step is important !
