Dear friends, everyone.
Can a friend help me? How can I tell me to delete the poster?
For example:
I accidentally added the first season poster to the second season, I want to delete it I can’t.
Thank you all.
For example:
Thank you all.
Best way:
perform the Plex Dance with the whole series
then add all the posters named after this guide beside the video files
https://support.plex.tv/articles/200220717-local-media-assets-tv-shows/
Or simply upload the correct poster and then edit the season and select it.
@OttoKerner Thank you !
I can choose, can’t remove
Performing the Plex Dance is the only way how Plex can “forget” old metadata.
