What do you need to know- downloaded
Take the ZIP File and drag it into the reply Window.
Give it a moment to upload (it will change to a URL)
Then click Reply again to send it.
Logs.zip (861.3 KB)
Thanks,
Your logs are clean with exception of PMS having forgotten it’s yours
Jan 01, 2023 14:50:27.333 [0x7f93a431b0] DEBUG - FeatureManager: Using cached data for features list
Jan 01, 2023 14:50:27.415 [0x7f93a431b0] DEBUG - HttpServer: Listening on port 32400.
Jan 01, 2023 14:50:27.416 [0x7f93a431b0] DEBUG - HttpServer: Listening on port 32401.
Jan 01, 2023 14:50:27.416 [0x7f93a431b0] DEBUG - Running server...
Jan 01, 2023 14:50:27.416 [0x7f8f592aa0] DEBUG - HttpServer: Set up a thread pool with 2 threads.
Jan 01, 2023 14:50:27.416 [0x7f93a431b0] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.35.5, threadsafe=1
Jan 01, 2023 14:50:29.252 [0x7f8f26daa0] DEBUG - [JobRunner] Job running: /volume1/@appstore/PlexMediaServer/CrashUploader "--directory=/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Crash Reports/1.30.1.6497-5fc2e0894" --version=1.30.1.6497-5fc2e0894 --platform=Linux "--platformVersion=DSM 7.1.1.42962-1" --serverUuid=7074f8a8ff688fd8b6d4ce9b6371595007ac8c7d --userId=NOUSERID --sentryUrl=https://o17675.ingest.sentry.io/api/1233455/minidump/ --sentryKey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx --vendor=Synology --model=aarch64 --device=DS220j --allowRetries=0
Jan 01, 2023 14:50:29.254 [0x7f8f26daa0] DEBUG - [JobRunner] Jobs: Starting child process with pid 26014
Jan 01, 2023 14:50:29.830 [0x7f93a431b0] INFO - SQLITE3:0x7f9491d4b8, 283, recovered 188388 frames from WAL file /var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal
Jan 01, 2023 14:50:30.182 [0x7f8fccdaa0] DEBUG - Jobs: '/volume1/@appstore/PlexMediaServer/CrashUploader' exit code for process 26014 is 0 (success)
To reattach (reclaim) your server and put it back on your account is very simple.
Below, I attached the How-To .
It’s a step by step, with screenshots of what you’ll see
You’ll want the DSM 7 instructions (Everything is done in the installation GUI menu)
so reinstall again on the dsm7 plex/
ill let you know how it goes-thanks for the help1
So the three options on uninstall- first option uninstall and keep/
Then manually reinstall and select claim plex token?
Yes.
Uninstall – KEEP option (the default)
Install (use the same SPK file again) - Plex Claim Token option + “Get Plex Claim Token” link & token pasted in
I believe i have it???
Awesome Chuck-have a great New Year!
Awesome job11
Next - Sonos controller won’t find the server??? Wtf😩
Any ideas- or should I contact Sonos
I’d contact them. I prefer vinyl and Polks myself ![]()
What tipped you off that the server needed reclaimed?
It seems to be something changed in 1.30.1 and it’s more susceptible to losing the credentials.
If you examine the logs and don’t see the server owner authenticate – it’s lost its credentials OR can’t authenticate (networking)
