Can you add [Language Code] to Movie filenames to avoid manual matching
Server Version#:1.20.3.3483-211702a9f
I have three libraries for MP4 Movies based on resolution.
Movies-4x3 (PAL movies)
Movies
Movies-HD
All have English as a standard language but contain Movies in other languages.
I know I can create more libraries with different languages, and
I use that for TV-Series but I would like to avoid that for my Movies.
I have a backup NAS and I sync them manually using a hard disk.
I would like to avoid having to manually match the non-English Movies twice.
Is there a way where I can either name the movie file or embed data in the movie
file so that Plex tries matching with the correct language?
Similar to the method used for sub-titles.
Have you looked at the audio track language of the movie files? If the language is labeled on the track, Plex recognizes it.
If you’re on a MAC, I used Subler to fix those files with mislabeled audio track language.
No. Plex will only auto-match using the library you’ve set for the library.
You will need to use multiple libraries if you want Plex to do this automatically.
