Cannot connect to PC Plex server within same network
Server Version#:1.21.2.3943-a91458577
Player Version#:6.7.6.6799-0ffd3d093
Hello,
Since upgrading my ASUS router a few days ago, I am not able to stream from my PC Plex server within the same network to any of my devices (Roku, iOS, and Android). A remote connection does work when enabled. Oddly enough, my NAS Plex server still works fine.
I have tried everything recommended such as allowing insecure connections and changing DNS to Google. I have not been able to modify DNS rebinding protection in the router firmware. I think this would require installing a non-OEM firmware. I have tried uninstalling and reinstalling the Plex server. I also removed NordVPN and that did not help.
I have attached my logs. Any help would be appreciated. Thank you.
Plex Media Server Logs_2021-01-29_08-11-24.zip (3.1 MB)
Make sure your network connection is Private not public. WiFi isn’t going to give the best results.
Some housekeeping, you have several failed sync jobs that need to be deleted and the Scheduled Recordings and DVR need to be deleted and recreated due to the EPG changes.
Thank you! That solved the problem.
