Cannot match channel
Server Version#: 1.40.0.7775
Tuner Make/Model: HDHomeRun CONNECT 4K (HDHR5-4K), Firmware: 20231214
Guide/Lineup name: Fox-9, Fox9+, Movies!, FoxWX, Circle, Outlaw.
Channel number/Name: 9.1, 9.2, 9.3, 9.7, 23.1, 23.2.
Channel lineup on HD HomeRun shows they are available, but Plex does not.
Screenshot HDHR
Is there a way to update the channel line up myself?
Are you sure? I tested ZIP code 55344 and the WFTC channels were available (Fox 9, MyNetworkTV, Movies!, and Fox Weather/FoxWX). (23.1 and 23.2 are available as well, but they show as The CW and Comet.)
If you select the check-boxes do you not have those channels available (they may not have auto-matched)? If not, it might be specific to the ZIP code you’ve chosen; try a more generic/regional one. If that works, you may need to report your specific ZIP code so Plex can have those channels added.
Thanks @pshanew for the suggestion.
When I looked at several other sources, such as TV Guide and Zap2It, they did not have the listings their either.
I am assuming these are new channels to the area and I will need to wait for the guides to update.
