Cannot start using plex!
Hi… I installed the plex app on a fresh WD myCloud EX2 Ultra following the instructions on the WD site. After going over to configure plex I log in the PMS, but then the media server is not found (i.e. on the left top of the plex page I read “Search for server” and below “No server found…”! I’ve tried different times, tried uninstall/reinstall, completely purge plex (via ssh), again reinstall… same thing!
Please, could anyone advice me in any direction?
Regards, Joe
Regards, Joe
could you locate the logs and copy out and zip the copy and attach
https://support.plex.tv/articles/200250417-plex-media-server-log-files/
https://support.plex.tv/articles/202915258-where-is-the-plex-media-server-data-directory-located/
Best to capture the logs after restart
If debug logging is disabled - then may need editing Preferences.xml to re-enable it
Sorry, I wasn’t available for a couple of days… but now, please, find attached the logs…
Regards, Joe
sorry, I’ve put the logs together in a tgz, but the forum does not allow this… can I mail them to you?
Why not zip the tgz and attach the zip
ok, I’ll try, here the zip…
Is this hosted externally or on your home network ?
You have a public IP address for the server
Apr 10, 2018 15:01:15.367 [0xb40d8000] DEBUG -  * 4 egiga0 (141.79.xxx.xxx) (loopback: 0)
You can only configure a server that is hosted on a Public IP range address through ssh tunnelling
See this support article https://support.plex.tv/articles/200288586-installation/
and read section headed On a Different Network
Alternatively, if this is in your own home network, change your local network subnet to be within the defined range for private networks - see https://en.wikipedia.org/wiki/Private_network
Indeed, the server is located at my university and has a public IP, that’s correct… so, what do I need to do, if my local PC, from which I do the configuration, is located in a different subnet?
read the suppport article i linked and the section i referred to.
You would need to be familair with linux
OK everything works! Thanks a lot!!!
