Can’t find a solution to this. Think i’ve tried all the suggestions in the forum. Movies and music work fine.
File structure is correct. Permissions seem ok. Just keep getting “There are no items in this library”
I have this issue on plex cloud. Any solution
Settings - Server - Network - ‘Show Advanced’ - IPv6 = DISABLE
It looks like you added each show’s folder individually to your tv show library.
You must not do this.
Only add C:\Users\Trevor\Desktop vidia dvds
and C:\Users\Trevor\Videos\TV Shows\
and make sure that both these folders only contain tv shows and not other types of media.
While you have the file and folder naming right, you are still doing it wrong.
You don’t add one particular show or even one particular season.
You only point Plex to the folder where all the different series are stored.
I gave you an example above.
That Worked! Thank you so much
