Server Version#: 1.28.2.6151-7000
Player Version#: 4.87.2
when I select + Your Media on the home screen, it displays the “Add your media to Plex” screen with a link to Plex Media Server downloads
thanks
thanks
great thanks, installed and applied the token as per instruction. When launching Plex from DSM, after selecting the user, the browser is stuck on the “Turbocharge your Metadata” pop up with no way to exit or select the upgrade libraries options
You can’t click on it ?
no, I cant click anywhere on the page
There are few reports of this.
To keep your PMS running, please go back to the previous version and hold there while we investigate further.
If you need the previous SPK file, please let me know what you need (NAS model and version you last had)
thanks, NAS is DS920+ on DSM7. This is a new NAS so I had no previous version of PMS on this NAS
Check your PM please. I’ve sent you a gift ![]()
Folks –
Engineering has asked for the log files if it’s possible ?
ZIP of the server logs and
Also please get the Plex/web logs
