Can't choose Library folder paths to store optimized versions
Hi there - thanks for the post.
Can you confirm what options you have under the optimize screen, because I only have “in folders with original items”, so don’t currently have an option to store the optimized files in a single place.
Maybe I’ve misunderstood your workaound?
I am seeing the same problem. I am on Plex server 1.24.5.5173 on Linux.
When I optimize an entire library, I can’t select the target directory.
Thank you X10^6! Just tried, can confirm worked like a charm, hope this bug gets fixed soon, would rather not have to do this
The same issue with Plex Server 1.24.5.5173 running on Shield.
Thanks for the suggestion. I tried this but am unfortunately faced with the following when I click “Optimize” having selected the option that I added in html:
Edit: This worked when I pulled the correct option number from the html for the individual video optimize prompt. Thank you!
Glad it worked but it’s extremely hacky, anyways.
Hopefully the Devs will fix the web UI as the server does support it (as shown by the hack)
