Can't claim my fresh PMS reinstall
Server Version#:PlexMediaServer-1.41.7.9823-59f304c16-x86_64
Hello
May 31, 2025 08:39:38.561 [28928] WARN - [HttpClient/HCl#256] HTTP error requesting POST https://plex.tv/api/v2/pins?strong=true (60, SSL peer certificate or SSH remote key was not OK) (SSL: no alternative certificate subject name matches target host name ‘plex.tv’)
May 31, 2025 08:39:38.561 [25360] ERROR - [Req#2f6] MyPlex: Failed to retrieve PIN: -60
I run PMS on windows 10, a few days ago i began facing issues with plex, network unavailable, can’t access to my libraries.
I figured out that came from claim issue.
I ve uninstalled PMS, even deleted my server
I ve deleted anything plex media inc registry keys and AppDate/local/plex files
and when i open plex i have that setup web page running for ever.
I’ve tried some claim tips found here
https://www.plexopedia.com/plex-media-server/general/claim-server/
but nothing helped
local plex has an authorized acess error
please help, i have a plex pass and i can’t create a new account
I even changed my plex password to disconnect all previous web apps
here are some server logs
Jun 01, 2025 12:28:04.489 [28564] DEBUG - Request: [127.0.0.1:59232 (Loopback)] GET /myplex/launch (3 live) #e82 GZIP Token ()
Jun 01, 2025 12:28:04.489 [19348] DEBUG - [Req#e82/HCl#8ad] HTTP requesting POST https://plex.tv/api/v2/pins?strong=true
Jun 01, 2025 12:28:04.490 [19924] DEBUG - Completed: [127.0.0.1:59232] 200 GET /myplex/launch (3 live) #e82 GZIP 0ms 3495 bytes (pipelined: 341)
Jun 01, 2025 12:28:04.866 [2496] WARN - [HttpClient/HCl#8a6] HTTP error requesting POST https://plex.tv/api/v2/pins?strong=true (60, SSL peer certificate or SSH remote key was not OK) (SSL: no alternative certificate subject name matches target host name ‘plex.tv’)
Jun 01, 2025 12:28:04.866 [29492] ERROR - [Req#e7b] MyPlex: Failed to retrieve PIN: -60
I was able to perform the server configuration while connected to another country with VPN…
no clue why
That is a hint that the DNS resolver in your router might be responsible.
Try the tips in here https://support.plex.tv/articles/206225077-how-to-use-secure-server-connections#toc-4
If your router or your ISP offer you an “advanced filtering” option of some type, it might be blocking sites which are necessary for proper functioning of Plex.
Thanks for your advice, but my ISP box doesn’t seem to block anything.
After i was able to perform server configuration while using vpn, all was fine, till yesterday and the same issue appeared
Jun 07, 2025 10:27:47.660 [28968] DEBUG - Request: [127.0.0.1:53455 (Loopback)] GET /myplex/launch (5 live) #70 GZIP Token ()
Jun 07, 2025 10:27:47.661 [24108] DEBUG - [Req#70/HCl#65] HTTP requesting POST https://plex.tv/api/v2/pins?strong=true
Jun 07, 2025 10:27:47.661 [4496] DEBUG - Completed: [127.0.0.1:53455] 200 GET /myplex/launch (5 live) #70 GZIP 0ms 3495 bytes (pipelined: 1)
Jun 07, 2025 10:27:47.756 [7404] WARN - [HttpClient/HCl#65] HTTP error requesting POST https://plex.tv/api/v2/pins?strong=true (60, SSL peer certificate or SSH remote key was not OK) (SSL: no alternative certificate subject name matches target host name ‘plex.tv’)
Jun 07, 2025 10:27:47.756 [24108] ERROR - [Req#70] MyPlex: Failed to retrieve PIN: -60
This is an indication that someone between your server and plex.tv is decrypting the SSL-encrypted data packets, and then encrypts it again with their own certificate.
Plex will not accept these packets, because there is no guarantee that they are unaltered.
See if your ISP (or your router) provides some sort of “enhanced security” feature.
Switch it off or put in an exception rule for the domain plex.tv
Anti virus software and corporate firewalls often do the same.
again i manage to regain access while using vpn.
I don’t understand since my server is on that comptuter, and i right click on open plex, (127.0.0.1:32400 address) i had you don’t have the rights to access
all i have on my isp router advanced option is this kind of option
but only from external port ** 8193 to 16383**
and i m trying to my own computer from itself
