Server Version#: Version 1.23.4.4805
Player Version#:2.013
downloaded the app on my smart tv.
downloaded the app and media server on my pc, win. 10
on the tv screen it says that i have to type 4 digits in the web to connect but there are no any digits, it’s grey empty
when i try to choose select player it says “no device found”.
Your particular TV model is unfortunately no longer supported.
thanks i guessed that this is the reson
Have you tried this?
Easy and been shown to work perfectly. I have a 2011 TV FYI and and continue using Plex no pb.
There is also a more sophisticated fix you can find on the forum, where you set a proxy server, and then you are not just connected locally, if that is important to you.
thanks.
i decided to continue with servio.
it’s serve my neds
