Can't Fix Incorrect Match..
Hi having trouble with my plex off and on with (Fix Incorrect Match) was working before then stop and I had it working again but now its back to cant finding match for anything at all…have two server with the same version of plex and the other one work ok…was wondering why that is?
are you getting an error or something? or just no results. Sometimes fix match search window will fill in the year wrong that it is getting from file name and not return results because of it.
