Can't get a claim token
So after the Codecs issue I nuked my whole plex server, before knowing it was not my problem. Now I spun up a new plex docker instance and was trying to claim it. I can’t do it manually or get a code from the website
Which Portuguese ISP are you using?
Set your computer or your whole network to use Google’s public DN S service on 8.8.8.8
Something is going on with Portuguese ISPs either blocking certain domains or neglecting to update their own DNS servers.
I am using meo, changed to Google’s public DNS and it worked! Thanks!
