Can't get a direct connect to work
Remote access works great, but when I go to app.plex.tv, it shows as an indirect connection. I searched a lot on the internet regarding this problem, but I can’t quiet make out a solution for me. I have found that if I disable “Secure connection”, the connection will become direct. I don’t know if it’s a problem that I’m not using a secure connection, but a secure connection sounds better to me… I would like a direct connection to use synclounge and maybe that direct connection will make my movies stutter less?
Anyone an idea to fix it? Thanks in advance.
see Computers on local network showing up as remote connections all of a sudden
I apparently can’t change the DNS on my router and I don’t see ‘DNS rebinding protection’ anywhere…
Is using a non secure connection actually that bad? If I only disable secure connection when I want to use synclounge for example, is it a big problem?
I am not familiar with Synclounge.
Only you can decide if it is bad that anyone with access to a part of the internet connection between your server and any Plex client can determine what you have on your server and what you and your sharees are watching/listening to.
If you are OK with that, simply disable secure connections.
In this case, bookmark this URL and send it to your sharees as well: http://app.plex.tv/?secure=0
Okay, thanks. I will use a secure connection most of the time, but now I know it’s not a really big deal that I disable it for a few hours when I’m watching a movie with a friend. Thanks again for the information/answer!
