Can't get manual portforwarding to, only unpn
Hi
I would like to set up so that my Windows 10 PMS works for remote access.
I can get it to work if I set it up using unpn, but if I use a manual port it doesn’t.
I have tried several ports and portforwarded them to my pms with a static ip adress.
I have checked for doubled natting, and that isn’t an issue either.
I have also tried disabled all anti virus and firewall and that doesn’t work either.
I have other programs on the same pc with port forwarding that works just fine.
It is only the pms that doesn’t.
see
I have tried that. And it doesn’t work
is a pretty nebulous description.
Did you try the port access test with canyouseeme.org ?
I have tried that and it says that the port isn’t open. But as mentioned in the first post i have checked for doubled natting, forwarded the port and disabled unpn in the router. Disabled the anti virus and the firewall. I don’t know what Else to try
I Seem to have found the problem. My router doesn’t seem to be able to forward from one internal port to another external port
Ah, so you have to use 32400 external and nothing else. That’s poor performance by the router.
