Hi all,
I have an issue that’s been driving me crazy for the past few days. I use Plex to stream my TV shows and movies, and it works great at home, it even works great externally, so long as I use auto setup. The only issue I have is that when I try to setup manual port forwarding, remote access won’t work.
The reason as to why I’m wanting to change the port manually is because of my network at uni, a lot of outbound ports are locked, so I have to get creative and use ports like 80/443 for my port forwarding. This shouldn’t be a problem, right? Well, so I thought.
Anyway, to the issue at hand. When I let Plex do all the work, without tinkering with the settings, it sets ports itself, usually using the 19000-26000 ports. I’m guessing UPnP is doing most of the legwork here. If I then try to manually select the ports I want Plex to use (I have tried 80/443/20040), that’s when the problem occurs. The Remote Access status message/page is green for about two seconds after I apply the settings, but then it turns red, and says “Not available outside your network”.
Port forwarding for me is straight forward, I host a lot of other web services from my home, and it’s never been an issue except with Plex. I use ports 22/25/80/443/3389/3478 actively, and they all function as expected. I’m very comfortable with networking, and am used to troubleshooting. I’ve even installed Plex on my Ubuntu server to check if my Windows-installation was bugged - to no avail, same issue occurred here. The ports do not appear as up, and canyouseeme.org confirmed this, saying they’re down when I have attempted to forward them.
Firewalls have all been attempted turned off, both Windows Firewall and the firewall on my router. It shouldn’t be an issue with my router, because I have tried multiple (not as the same time, so don’t get confused with a double-NAT issue, that’s not it), and none seem to work with Plex specifically, when everything else still port forwards as expected. When I try Plex externally while the Remote Access page shows red, I get redirected to your typical “Indirect connection”-page, using one of Plex’s relays which caps my streaming to 1Mbps - no go.
I have studied this page, https://support.plex.tv/hc/en-us/articles/200931138, but this page seems to be for those experiencing trouble with auto configuration and UPnP, which works flawlessly for me. Double-NAT is is not a problem, and I have assigned static addresses. I even checked jumbo frames, but MTU size is set to 1500.
If there are any logs you guys want to see, or if you need additional details of what I run, please let me know.
Network: ISP -> Modem -> Router(s) -> Cisco switch -> Windows Plex Server (main) / Ubuntu Plex server (for troubleshooting)
Routers: Netgear N600, ZyXel P8702n
TL;DR - Plex Remote Access works when Plex auto-assigns ports, but will not work when I try to manually assign ports,
no matter what ports I try. (80/443/20040).
If I posted this in the wrong section, please direct me to the right category.
Thanks in advance. Sorry for the wall of text.
