Can't get Plex to use metadata tag for home movies
I am trying to add metadata to my home movies. They are mp4 from my cellphone. I used a tag editor and added a title to the metadata tag. To be clear, I’m talking about the tag embedded in the file itself, not when you go to the library in Plex, click edit, and edit the info.
The library is an “other” type. I have the scanner set to Plex Video Files Scanner and the agent as Personal Media. I went to agent in the settings to put the local media assets as higher priority but it has movies, shows, artists, albums, and photos. There is no “other” listed. Still, I have local media assets for movies set as the highest priority. I’ve tried removing the file from the library and emptying the trash and moving it back but it didn’t help. I don’t have the “optimize database” and “clean bundles” options anymore. It still just shows the title as whatever the file name is.
How can I get Plex to use the metadat from my video files?
You’ll want to check out Movies > Personal Media in the Agent settings. That’s where Local Media Assets needs to be checked and treated with a high priority. This worked for me quite nicely… I’ve even got individual family members to show as „actors“ within Plex for filtering :wink:
That is what I have already. I’m not sure why it’s not working.
Try the Plex dance again… including the clean bundles part… if it’s not available on the home screen you should be able to find it in settings > manage > librarsies.
It doesn’t seem to be in the settings either. I get the same options as I do in the home screen. No clean bundles option.
EDIT: I found it under settings > manage > troubleshooting. I tried the dance a few times but I’m still getting the same result.
Which metadata fields exactly are you using in the MP4?
also clean bundles was added here so you don’t have to go into settings.
08%20PM
At first I just tried ‘title’ but added a few more to see what would work:
The name of the file is test.mp4 and ‘test’ is what keeps showing as the title instead of ‘title’.
Optimize and clean bundles used to be there but it’s not anymore. Server is Version 1.18.1.1973:
What app are you using to embed metadata? Just want to give it a try if I can but look like you may be using Windows.
also what shows as the GUID when you view XML for that item. (Get info>View XML)
it should look like this. mostly want to know if it says agent.none or if it says local
guid="com.plexapp.agents.none://gobbledygooknumbers?lang=xn"
guid=“com.plexapp.agents.none://89d7841c75a0648a7204b43061acb8e7c01674c3?lang=xn”
I tried a few apps for the metadata. I tried tag&rename and mp3tag. I think I also tried dbpoweramp at one point. The server itself is a linux docker image.
none is the personal media agent. so that is a good thing.
The Title field should work.
I don’t have windows so can’t try those apps but will ask some folks what they use.
mp3tag can write almost every tag type which Plex is able to ingest.
And it can ‘optimize for streaming’ the mp4 file afterwards. (which is always a good idea if you happen to use a streaming server – like Plex is.)
Another thing, maybe it’s nothing but it doesn’t ever seem to match. If I match it, it still has the ‘match’ option in the menu, not the ‘fix match’ or ‘un match’.
(just noticed you added image of trying to find clean bundles. need to do that from the server name not the individual library. notice mine says Manage Server rather than library)
Can you try this file out that I know works as I just made it. If it does not work can you grab the server, scanner and local media logs (last one is in plugin logs folder) https://drive.google.com/file/d/1vsbhSG1DdZ5MNMtUW0v79th20qxnztiH/view?usp=sharing
55%20PM
Well, that file worked just fine for some reason. I think Plex has a problem with the files themselves. I can change the tags on the file you gave me with mp3tag and they change in Plex. The file uses the same tags I am using. I even tried copying the tag of the working file and pasting it into the one that isn’t working but it didn’t work.
what type of cell phone do you have. maybe one of us has the same and can check the files from it.
Pixel 3. The video is in 4k. I made a short video and uploaded it in case that will help.
Any other suggestions.
I’ve been checking out your video… it appears that Plex indeed has an issue with the video because the header isn’t optimized.
ActionResult
Added your file as-isNo metadata showing
Added Metadata (a lot of ) to your file before adding it to PlexNo metadata showing
Optimized the file ahead of adding it to PlexAll Metadata showing up nicely...
I’ve been using subler (macOS only mp4 tag editor)… they describe their Optimize function like this:
What’s the “Optimize” function ?
It interleaves the audio and video samples, and puts the “MooV” atom at the begining of the file, restoring the Quicktime “fast-start” (also known as “pseudo-streaming”) ability of the file.
When you edit the metadata… did you actually use mp3tag as proposed by Otto? According to their documentation this will also optimize the file header / structure (supposedly automatically; optionally via the context menu – however I cannot confirm this at the moment).
Mp4 optimization must be triggered explicitly in mp3tag. (Right-click on the file)
I just tried the optimize option and it didn’t seem to work, even when doing the dance. I’ll try again later with another file.
