Can't Match...themoviedb
I have a movie titled &Me from 2013 which matches themoviedb at:
This is also how it is titled on IMDB (however it looks like IMDB is no longer an option for matching):
However, no matter what I try, Plex will not match this movie…
Does anyone have a tips/tricks to get this to match?
Thanks…
If you need to fix-match it anyway… have you considered simply searching by the IMDb / TMDb IDs respectively (Plex Movie → IMDb ID, The Movie Database → TMDb ID)
Edit:
Matching the movie using the Plex Movie agent worked right away for me (automatic + manual matching):
Movies
  &Me (2013)
    &Me (2013).mkv
(leaving out the leading & resulted in a bad match though)
I finally was able to get it to match…
