Can't reach PMS on Synology DS218+
Server Version#: 1.15.2.793-782228f99
Player Version#: 3.83.1
Hello
after updating the server to version 1.15.2.793-782228f99, i couldn’t reach the server anymore.
So i reinstalled this server version, but it still didn’t work.
I deleted the PLEX user und the common folder. → didn’t help
So i installed the older version 1.13.4.5271 but it doesn’t work either.
Now i have no clue what to do.
I would be very thankfull when someone could help me.
Thanks a lot :slight_smile:
Hey
Thanks for your answer.
I followed all these steps (i also deleted preferences) but it still doesn’t work.
Maybe i am too silly to run the .\claimpm.sh in the right way.
login as: Matthias
Matthias@192.168.1.100’s password:
Matthias@Multimedia:~$ sudo -su root
Password:
sh-4.3# cd "\Volume 1\familie
.\claimpms.sh
But then there doesn’t happen anything?!
If I may add to trumpy’s post,
Some systems are stubborn:
  1. Sign out of the Plex/Web app (upper right corner
  2. Open an incognito window
  3. In that new window: http://ip.addr.of.syno:32400/web
Presuming you are on an RFC1918 compliant LAN (should be), it will load the Plex/Web app.
Sign it in again there and proceed forward.
Start the setup wizard again, doing a normal setup except Do Not Create new library sections. Your original will be waiting for you at the dashboard so SKIP the creation steps.
Once all signed back in, you will be again able to find the server normally.
ChuckPA
I will try this right now.
I signed out and opened a incognito windows in chrome.
then i opened : http://192.168.1.100:32400/web
But it still comes this picture
And of course, the Server Version is now 1.15.3.835-5d4a5c895
when trying to resolve and make it work, changing versions mid stream isn’t advisable.
Your browser is looking for the old version. we need to clear it
  1. Stop Plex
  2. Delete the preferences.
  3. start Plex
  4. Clear your browser history of today
  5. Now open incognito window
  6. In that window, http://192.168.1.100:32400/web (or just click this link)
  7. If you do not see a sign-in, show me what you do see
I followed your steps.
There was a sign-ign (picture)
I logged in with my email
And then there is picture 2
Ok i am too silly to do it right.
If i type: sh-4.3# cd “/Volume 1/Familie”
the answer is:
           sh: cd: /Volume 1/Familie: No such file or directory
cd "/volume1/Familie"
There is no space and it is case sensitive.
I’m so ■■■■■■■ sorry, that i am so stupid:D
maybe “/volume1/familie”
ls /volume1 will show you all the files.
I am using this on a Synology DS218+
I will pointout… spaces are important in Linux
ls /volume1
is what I was hoping for.
I will let trumpy take over.
STRG+V didnt work but i entered it and It worked!! Yeah you are so patiently.
What is the right Plex.TV Username?
My email-adress?
IT WORKED!!!
I LOVE YOU ALL :slight_smile:
thank you so so so so much for your help!!!
i love plex and the community!
Ahhh i am so happy:)
So now i have problems again.
after entering Email,Password and IP i geht this **Error:
We failed to get the Plex Media Server ID
Please check server is up and running, as well as the IP address entered
Of course, it is still the same IP- address and the server is up and running
I also deleted the preferences
Server version: 1.15.6.1079-78232c603
EDIT:
i deinstalled and reinstalled Plex and then the error did not appear again and claiming worked.
I hope, that i do not have to do this every 3 months
