Can't redetect deleted TV Series
Server Version#: 1.28.0.5998
Series in question is Feud (2017). When first uploaded it detected fine, but one episode was in twice with different numbers. (My mistake.) I replaced the first and renamed the second. Then it detected the renamed episode as a separate season. Made multiple efforts to move, rescan library, fix metadata, etc. Eventually deleted the show.
Now the entire series won’t detect at all, despite multiple tries with the Plex Dance ritual. Naming conventions appear correct. I can see some errors in the logs, but I’m not sophisticated enough to know what they mean or how to fix them.
I’m stumped.
Plex Media Server Logs_2022-07-25_13-03-05.zip (2.4 MB)
Your logs say it can’t find the folder your library points to.
The system cannot find the file specified: “M:\PLEX\SHOWS”
Ouch, that hurts! I had tried a couple of times with that folder name, and when it didn’t work I tried renaming to TV SHOWS and thought I had pointed to that one. Guess I’m a bigger noob that I thought. Thanks!
