Can't scan channels for Bathurst, NSW Australia
HI,
RE: Plex “stalls” during scan channels
I should be able to get these channels – https://www.yourtv.com.au/guide/orange-dubbo/
Steps to reproduce:
I have installed hauppauge WinTV-dualHD on a windows 10 PC and installed their WinTV8.5 product to install all the device drivers. All the channels work using WinTV8.5
On the same PC I have installed Plex server 1.14.0.5470.
  1. I have run “Set up Plex DVR”
  2. Plex finds my Hauppauge card.
  3. I select scan channels for Australia (my specific region is not available)
  4. I wait a long time.
  5. Plex says it has found 144 channels and is at 99%.
    It stays on 99% for a long time
These lines are repeated over and over in the console (for over 20 minutes)
Dec 15, 2018 15:51:20.960 [9660] Debug — DVR:Grabber: Found 60 scanners.
Dec 15, 2018 15:51:23.960 [9660] Debug — HTTP requesting GET http://127.0.0.1:32600/devices/compound_device041dvb%23bda%23usb%23vid_2040%26pid_0265%230014040293%23
Dec 15, 2018 15:51:23.980 [9660] Debug — HTTP 200 response from GET http://127.0.0.1:32600/devices/compound_device041dvb%23bda%23usb%23vid_2040%26pid_0265%230014040293%23
Dec 15, 2018 15:51:23.986 [9660] Debug — HTTP requesting GET http://127.0.0.1:32600/devices/compound_device041dvb%23bda%23usb%23vid_2040%26pid_0265%230014040293%23/scanners
Dec 15, 2018 15:51:24.037 [9660] Debug — HTTP 200 response from GET http://127.0.0.1:32600/devices/compound_device041dvb%23bda%23usb%23vid_2040%26pid_0265%230014040293%23/scanners
Dec 15, 2018 15:51:24.039 [9660] Debug — DVR:Grabber: Found 60 scanners.
