Server Version#: 1.41.2.9200=70009200
Player Version#: irrelevant
Hello,
I have media files stored on a USB drive attached to a Windows 10 PC. I configured the directory for sharing. I mount that directory on the Synology. The mount succeeds (verified two different ways: From Network on the Windows machine, I can view the Synology’s available shares, click on the shared directory, and see the files. From the Synology, I can use the File Manager to drill down to the directory where I’ve mounted the Windows file share, and see all the files.
I then configure the Synology Plex Media Server to use that mounted directory as the Library. No files are available in the Library even after I rescan and also try restarting Plex Media Server.
Why can’t the Synology Plex Media server see my Library? BTW, if I install Plex Media server on the Windows machine, and point its library to the exact same directory, it works perfectly.
