I’ve installed and opened Plex on a Synology 412+. When I attempt to nav to my media on the NAS, the Plex dialog is already puzzling to me. I click “Add Library”, select “Movies” type, click “Next”, and “Browse For Media Folder”…which then shows me a directory tree that begins with Plex showing me root “/” and two other directories that are unfamiliar to me by name “volume1” and “config”. Eventually, I figure out that “volume1” is the root volume I created years ago when I got the device (and normally never see). Within this volume I can find my NAS shared directory “NAS”. When I choose this directory, I’m not allowed to browse any further down the tree, and can only nav back up the tree. If I manually complete the directory I’m actually seeking “volume1/NAS/_xcoded moov” nothing happens and Plex tells me “There are no items in this library”.
This stops me dead in the water. I have no idea why Plex can’t see the hundreds of bog-standard mp4’s in that directory.
Can anyone explain to me what’s going on here? I can’t even perform the basic task of pointing the app at my main media directory. Thanks.
OK, it appears my topic has been moved…I purposely didn’t choose this thread because I don’t think I have a NAS or Synology-specific problem? Do enlighten me if I’m mistaken.
Yes, I’ve been looking at that faq…but how strict is naming to the display of media generally (ie non-serial content)? Obviously, all of my media is named, and more or less according to Plex standards (at least for standalone titles like movies)
Do I need to do anything else? When I force a rescan, Plex still tells me “No items in this library”. Note that I’m manually typing in /volume1/NAS/_xcoded moov into directory field, which Plex does not allow me to navigate to via the “Add Library” tool.
Ok, I’ve already done the r/w permissions, thanks to Chuck’s advice. Now I’ll try renaming the media folder to be without the ‘_’ underscore and see if that changes behavior…
for the media folder…the only folder that has an underscore. (Why does Plex not allow browsing beyond the root directory? ie ‘/volume1/NAS’? Seems counterintuitive to the word ‘browse’)
