Can't use same subtitles for different users
I downloaded subtitles via the more… feature in the plex media player
subtitles
However on the screenshot what you seeing is on another user and I can’t select it/download it. Any idea how I can get this fixed? The other user and me use the same exact subtitles for some shows.
You cant, since Subtitles searches are saved for each user separately.
Ref: https://support.plex.tv/articles/subtitle-search/
Thank you for the reply, so if a subtitle is in use i can’t download it on a another user to?
The subtitle downloaded by you is yours, and yours only!
Your user must download one as well :frowning:
Thanks again for the reply.
Well that’s my problem, I can’t download the same exact subtitle on the other user (see screenshot) it’s checkmarked and i can’t download it.
Thank you once again
Please update your server. This bug has already been fixed.
Thank you OttoKerner and dane22!!
