But the new version… Wow! Loved it! Thanks for that.
I’ll take a screenshot and post it here later
Everything works perfectly AFTER the initial launch. When you start plexamp you get the three headers with black screen. Each header will also give you black screen except charts. After you start any song everything then works perfectly. Hitting back will make everything work
any chance of a log showing this? what ios version?
Ios 15.1
Log you mean the plexamp log?
The issue I was having may have been related to connectivity. I notice that it happens often when I’m in poor coverage 5G areas. Pressing back just makes the screen blink but it is still blank. I also noticed that when playing a single song from recently added, I was not able to press the repeat button twice to enable “repeat one”. Not only the icon never changed to the arrows with the little one on them but also when pressed, it did not repeat the song.
