Plexamp Carplay Blank Screen
Hello i have an iPhone 6s, iOS 13.6.1
my Carplay apps, Spotify/Waze/Google maps/Audible/SomaFM/BBC Sounds/Libby/ all play and work correctly in my 2021 VW Passat,
but when i use Plexamp the audio plays through ok and the now playing screen looks and works correctly, but i get the Blank screen with three hidden buttons at the top that turn blue if you push them, then a scroll wheel appears and then “Null” is shown,
i used to be able to use Plexamp with no problems until the last three updates have happened, this is very frustrating as i spend a lot of time on the road and Plexamp was a great way to enjoy my music, (i have a dedicated Plex server purely for music)
The version of Plexamp is currently running is 3.9.1 which is supposed to fix the Carplay issue.
As all of my other Carplay apps work fine i know i do not need to update my iOS or even my VW infotainment software, it just seems there is a bug that is not being fixed with the updates that keep appearing for Plexamp.
my VW has wifi Carplay, i have tested Plexamp with a USB cable and WIFI Carplay and both show the same fault also the VW IS RHD and the other apps and Plex amp originally was displayed correctly for RHD vehicles
Any help would be much appreciated
Cheers
Lambpie
is there any reason you don’t update to a more recent iOS? it suspect that would resolve the issue.
