CarPlay UI broken in Plexamp 3.8.0
Hello,
in the latest Plexamp update (3.8.0) the UI of the selection Screen in CarPlay is still grey.
I have added a picture of the screen.
Please fix it.
What version of iOS?
Hi Elan,
the IOS version is 15.1 (old Plexamp releases works fine).
Same here. Very frustrating.
iOS 15.1
Same here, iOS 15.0. Just a blank screen same as above.
don’t worry, we will fix as soon as we figure out what’s going on!
Yes i have this problem too, in the latest Plexamp update.
The only thing i see is the playing screen.
Same problem. Ios 15.0 and 15.1. Both black screen
Same here. iOS 14.8 iPhone SE2020
The “Now Playing” screen works and audio works but pressing Back just gives the black screen shown
Commenting to follow. iOS 15.1 here.
Not sure if it is the same bug or related, but I am only seeing the repeat button.
No shuffle or rating buttons.
We’re investigating!
Promise it’ll look sexy when it actually works :laughing:
I think we figured out the issue.
Waiting on Apple to give us what we need to fix.
:crossed_fingers:
Any ETA on this?
ios 14.2 on iPhone 12 pro max using Plexamp 3.8 does the same thing. It will still play stuff as long as you use your phone screen. I also use the third party app Prism to interface plex and its working fine on carplay.
We’re testing a possible fix, but you have to factor in Apple’s approval timeframe, which is variable.
Partially working now. Still getting a blank screen every once in a while
Is that when starting up? Going Back should show a working UI?
Hi Elan,
Tried that. Also tried disconnecting, reconnecting the cable and even restarting the phone on that occasion.
To ask specifically: what happens when you hit Back on the player screen?
