1080P content is also an issue. It seems to be content from BBC iPlayer using Get_iPlayer.
I think Iām having the same issue - I watch a bit of live TV (itās still very common in Australia), and some channels are now unwatchable on my CCwGTV (I tried multiple ones, they are all the same).
The Firestick 4K Max and Windows players all play the same TV channels fine!
What Iām seeing is the video constantly stops and the spinning circle appears, then it might play for a split second, then stop etc. When I go to the Windows admin interface to see what itās reporting, itās saying itās āBufferingā.
Itās specifically happening on SBS HD channels (logs are attached of me trying to watch the show āHeritage Rescueā).
Iāve gone through the entire Australian (Melbourne) TV List and found some very inconsistent behaviour⦠and a lot of the HD channels are now transcoding which they didnāt do before! i.e. even 1080p hw converting to 1080p⦠!?!
10 Peach - 480i - Direct Stream - Plays fine
10 Bold - 1080p (H.264) - transcodes to 1080p (!!!) but plays fine.
10 Shake - 480p - Direct Stream - Plays fine
10 HD - 1080p (H.264) - transcodes to 1080p (!!!) but plays fine.
ABC TV - 1080i (H.264) - Direct Stream - Plays fine
ABC TV Plus - 480i - Direct Stream - Plays fine
ABC Me - 480i - Direct Stream - Plays fine
ABC News - 480i - Direct Stream - Plays fine
SBS HD - 1080i (H.264) - Direct Stream, buffers like crazy and unwatchable
SBS Viceland HD - 1080i (H.264) - Direct Stream, buffers like crazy and unwatchable
SBS World Movies - 1080i (H.264) - Direct Stream, buffers like crazy and unwatchable
SBS Food - 480p - Direct Stream - Plays fine
NITV - 480i - Direct Stream - Plays fine
7 HD - 1080i (H.264) - Direct Stream - Plays fine
7 two - 480i - Direct Stream - Plays fine
7 Mate HD - 1080i (H.264) - Plays fine
7 flix - 480i - Direct Stream - Plays fine
9 HD - 1080i (H.264) - transcodes to 1080p (!!!) but plays fine.
9 GO! - 480i - Direct Stream - Plays fine
9 Life - 480i - Direct Stream - Plays fine
9 - 1080i (H.264) - transcodes to 1080p (!!!) but plays fine.
9 Rush - 480i - Direct Stream - Plays fine
EDIT - From bbro_spoās suggestion above, I dropped Home streaming maximum quality down to 720p to force transcoding, and all the SBS channels now play fine like thatā¦
In the previous versions, all channels played fine as Direct Stream (no stuttering, no transcoding etc).
TV Buffering.txt (191.6 KB)
This is the media info of a problematic video.
Media
- Duration 10:05
- Bitrate 5192 kbps
- Width 1280
- Height 720
- Aspect Ratio 1.78
- Video Resolution 720p
- Container MP4
- Web Optimized Yes
- Audio Profile lc
- Video Profile high
Part
Duration 10:05
File s01e01.mp4
Size 375.46 MB
Audio Profile lc
Container MP4
Has Thumbnail 1
Web Optimized Yes
Video Profile high
Codec H264
Bitrate 5064 kbps
Bit Depth 8
Chroma Location left
Chroma Subsampling 4:2:0
Coded Height 720
Coded Width 1280
Color Primaries bt709
Color Range tv
Color Space bt709
Color Trc bt709
Frame Rate 50 fps
Height 720
Level 3.2
Profile high
Ref Frames 4
Scan Type progressive
Stream Identifier 1
Width 1280
Display Title 720p (H.264)
Extended Display Title 720p (H.264)
Codec AAC
Channels 2
Bitrate 128 kbps
Language English
Language Tag en
Audio Channel Layout stereo
Profile lc
Sampling Rate 48000 Hz
Stream Identifier 2
Display Title English (AAC Stereo)
Extended Display Title English (AAC Stereo)
Codec MOV_TEXT
Language English
Language Tag en
Stream Identifier 3
Display Title English (MOV_TEXT)
Extended Display Title English (MOV_TEXT)
The 9.16.0.38326-beta does not address this issue.
Plex is unusable after latest update on Chromecast with Google TV. Stuttering Street 10 seconds the Plex restart.
Now the skip intros has disappeared too. Never seen such a horrible update. Literally ruined the program.
@sixones Any update?
Any news please? My kids wonāt leave me alone! ![]()
Just to add an āI have this problem too commentā ![]()
Repro Steps
In regards to content the issue appears for me to be 720p content from Get_iPlayer, similar to:
Casting the same content from the iOS Plex app to the same CCwGTV works fine the same as:
Workaround
Following the steps mentioned by jebrossard and knoll
Send Files to TV app (install on both phone and TV)
Enable developer options on the Chromecast - Get to the build number under the about option and click it 7 times.
Install a file explorer (FX Explorer is an option) if needed
Make sure to uninstall the Plex App
Send the file from the phone to TV via the Send Files to TV app
Open the file in either the Send Files to TV app or FX Explorer app
It will ask to allow install from unknown sources and toggle the apps to allow from ( Send Files to TV or FX Explorer)
The app will then install
I have been able to restore my plex app to working order on CCwGTV.
One slight difference to knollās instructions was that I do not have an android mobile to send the files from. Instead I made use of FX Explorerās web based file transfer portal (pro feature but can be used for free for 7 days) to transfer the APK from my Mac to the CCwGTV.
Not sure if that helps anyone but thought Iād mention it.
This has been a nightmare to track down but Iāve found the problem was down to a single commit in ExoPlayer v2.80.2. Iāve managed to resolve the problem and can playback the sample without issues on the Chromecast with Google TV now.
Hereās an APK you can try;
Edit: wrong APK link.
Awesome news! Iāll try this tomorrow, too busy with work and Valentineās day to try it today.
The 9.17 AKP has fixed my issue with the SBS channels (Live TV) - they actually play now ![]()
Phew!!! I look forward to the change being committed back into the baseline ![]()
Thanks for the effort. At the moment I am not able to side load the APK. I am wondering when it will be live to download the usual way please? Thanks so much.
This build did fix my issue.
I do have a question. You mentioned ExoPlayer v2.80.2, yet when I go to https://exoplayer.dev/ the latest version is r2.18.2. Is Plex using a custom fork of the code?
Since this is a development version that isnāt yet in beta test, I would guess you wonāt see it through normal channels for a week or two at least.
Apologies should of been v2.18.2, but yes we do use a custom fork of ExoPlayer as we demux everything via FFmpeg and not the ExoPlayer demuxers.
Itās likely you are experiencing a different issue then, do you have a sample of a video that has the problem?
Uh, as I said, the APK you linked DID fix my issue! ![]()
Sorry, thought you said didnt
Thanks for confirming!
@sixones Appreciate your tracking this down.
Any thoughts as to when this will hit the beta users on Google Play? If itās a few days Iād prefer to just wait and not have to sideload devices. Thanks again!
Iām assuming this would impact all Android client users on this exoplayer version (Shield Pro, etc)?
(Probably same issue being discussed here: TV shows on shuffle causing plex to crash on Nvidia shield)
No problem. I watched three hours of 720p content last night. The only issue I had was the experimental version was it crashing once during playback. Playback got jerky for a few seconds and then the app crashed and restarted.
There was a different memory leak during playback that was fixed in v9.16.1, will update the build tomorrow to include that fix. Short term work around is to back out of playback after an episode plays.
The fix above will be in the v9.17 beta that will be released next week.
